what belt for a desmog? (1 Viewer)
N. West CT.
I am doing a desmog on a 2f and i was wondering if anyone knew off hand which belt is used to replace when the pump is gone. I believe the belt then just goes crank to fan/waterpump?? thanks
Trapper50cal
TEQ Frame of Mind
Supporting Vendor
Durango, CO
Hence the existence of the idler pulley. The smog pump was the tensioner for that belt (the alternator is the tensioner for the other) You need to get in touch with JimC and get an idler pulley and install it with a stock belt or equivalent shape and length GreenStripe. Its always good to replace belts before they break that way you have a back-up
3_puppies
Helena MT
X2....or you could pull the vains out of your smog pump and re-install, thus creating an idler and a way to tighten the belt
San Diego858, California
I put a GM alternator with a LC pulley there as a tensioner
It's not hooked up electrically but makes a much longer lasting idler
It's all coming out as soon as I start the V8 swap
Meridian,TEXAS
bolt on tensioner pulley
Here is a pic of a idler that I use.... Toyota # 16630-61020 used on 3F applications and it's easy enough to bolt on using the lower smog pump mount and p/s pump at the top..........
Uses the orginal belt and its affordable.....
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
