OEM coils should be around 70-80 each, spark plugs about $8 each. At worst, parts is $700, labor book gives us 1.5 hours to do spark plugs for this engine, that shop is charging you $1000 an hour wtf?
Torfab said they would only take an hour but are booked until February. They are trying to see if they can fit me in but how much damage could I do driving 46 miles, about an hour from where I live?
Thanks
Thanks
Wait, did you say you found squirrels living in your engine bay? I don't remember seeing you mention that you had misfire codes before the alternator/battery fiasco. It wouldn't just start misfiring after that, check wirings make sure nothing is chewed up or any hoses torn.
My guess is continued driving on your failed alternator caused the spark plugs to foul up. Was there no dash light when the alternator failed? I tell the wife, "Red dash lights, pull over immediately. Orange lights, continue but call me."
Personally, I'd change all the spark plugs and then fire it up and run the codes again. If misfire persists, I'd just buy two Denso coil packs. Replace the bad one and keep one in the vehicle as a spare. It is unlikely 3 coil packs went out at the same time. When one cylinder misfires, often it'll throw codes for other cylinders as well.
What the hell are they changing for $2000? That is unreal.
Plugs and coils are dead easy - less than a hour with a basic 3/8" socket set.
Sparkplugs.com has NGK 3764 BKR6EIX-11 plugs for $7.49 ea * 8 = ~$60
Coils look to be $62.20/ea, and you appear to need at least 3.
So, there is $250.
I hope I am misunderstanding something, because at $1750/hr I need to move to Seattle and become a mechanic.
Since they are relatively new, you can try burning off the carbon with a torch. If the white ceramic insulator is blackened like shown below, the plug is fouled from the carbon build up.I can give that a try. The spark plugs were changed April 2019.
I ordered 8 ea. Denso 67313003 Ignition Coil's and 8 ea. Denso (3297) SK20R11 Spark Plugs and figured I'd just replace everything while I was going to the trouble. Of course there is the chance I don't need to replace any of them but I would have needed to replace them eventually anyway.
The spark plugs come with the appropriate gap correct?
I've scanned a YouTube video and it doesn't look too hard. I don't have any torque wrenches though. Any suggestions for the primary tools and sizes I would need?
The quote from Doxon Toyota, the dealer that replaced my alternator, was $2,408.72 plus tax and everything else they always find. I'm at $560, tax included and a few scraped knuckles and some practice with my french.
Thanks.
Honestly I did a lot of work myself without a torque wrench back in the day and I was fine. Now with kids in the car I torque stuff properly. My Tekton has good reviews and was under $50 on Amazon. If you plan to DIY anything else its a good investment. I'd say just snug them up good if you don't want to buy a torque wrench, but there are a few documented cases of 100 series plugs backing out
You can do all the plugs and coils with a pretty basic socket set. You need some extensions, and maybe a wobble socket (knuckle whatever you call it) plugs are a 5/8" socket or a 16mm. I think the coils are held by 10mm or 12mm bolts. Air box is the same. Be careful when removing the vacuum lines the nipples break easily
I should have everything, maybe even a torque wrench I've forgotten about. If not I'll ask neighbors or just buy it. Thanks.
