What battery for an HJ45?
Hudson Valley NY
I have searched around but can't seem to find anyone recommending what the optimal battery is for an HJ45. I am not running a winch or any accessories, just need something that can reliably start it.
fjwagon
When I needed a battery I looked for a US straight diesel with glow plugs type application. Once I got the type of battery I needed I made sure the terminals were in the right locations. I got mine at Costco. And if you are in cold environment plan on installing an engine block heater if you have not already.
Adelaide, South Australia
Go at least CCA of 800 and make sure your glow system is in tip top condition. N70ZZX is my goto battery in Australia for the 2H engine in the 47s (H is a little smaller, but is the same basic tech as the 2H and the battery mount, terminal positions are the same) - unsure what the N70ZZX translates to in your corner of the world.
Victoria, BC
31P series from local rig shop. 1050 CCA and 210 reserve capacity. Double check its length compared to your battery tray. It should fit but I don’t own a diesel. They are built to be abused.
Hudson Valley NY
Thats interesting. I think the tray is a 27 size...need to see what I can fit
Victoria, BC
31 is about the same width but slightly longer… it’ll depend on now tight a fit it is.
Victoria, BC
Victoria, BC
Worst case you could replace the tray with one like this:
Amazon product
Although the illustration shows the top hold down wrong. 🤷‍♂️
