What are these electrical items 1976 FJ40 (1 Viewer)
macdaddy59
Niceville, Florida
So my 1976 FJ40 project came in pieces in boxes. I have finally got around to the electrical box. I have no idea what these things are and if I need to use them, replace them or what. Any help would be appreciated. I am installing a 2F out of a 1987 FJ60 to replace the SBC motor set up if that helps things a bit. The small black box says it is a seat belt warning device. The small gold cube says it is a buzzer. Not sure about the others.
brian
lebanon,pa
Big one at 6oclock....smog computer
Plated one above it....horn relay...
Black one at 3 o'clock...voltage regulator
macdaddy59
Niceville, Florida
Thanks, I don't have any smog equipment so I can disregard that one. If I am using a motor and alternator from a 1987 FJ60 do I need to get a different voltage regulator than the one pictured for the 76 2F motor and alternator?
jblatz
GOLD Star
on the trail...
Looks like your 40 is a California spec 76. The black box at 6oclock is the cooling fan relay (85927-60010).
The part at the top with the white connector is the throttle position switch.
The gold cube is the seat belt buzzer, which works with the black box underneath, the seat belt relay.
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
If your installing a sniper kit ?
You will need one of these , one of those and 2 of your choice stainless steel or #7 yellow zinc plated bolts too
FYI
Pm me if you have not solved this going to be a issues for you unless you pre plan sniper and do
