Long bolts are for fairlead to "eyebrow". Remove pins on vertical rollers and replace with bolts. Have to re-drill the fairlead. Two thick spacers are for fitting factory tow hooks on the bottom of the bar. Finger shaped bracket is to offset the solenoid from the motor on the winch. Finger is clamped by the hose clamps on the motor and other side bolts to bottom of the solenoid box.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
