Birfield CV joint part number 43405-60070, the birfields used in US spec FZJ-80's between 1/95 and 1/98, and number 43405-60080, the birfields used between 4/94 and 1/95, have slight differences best as I can tell. I'm writing this thread to ask if anyone knows any of the specifics or why the part may have been changed after just a short run of 8-9 months?
Looking at a non-OEM 43405-60080 it appears to have a beefier bell with a different contour both around the inner lip and outer circumference of the bell. The star has a different contour of the top surface (small bolsters). The weight of the -60080 (7lbs 12 oz) feels heavier than the -60070 as I remember that one.
Anyone got a spare -60070 (stock 95-97) birf laying around they can weigh and get some measurements from??
Approximate measurements of a non-OEM 43405-60080:
Diameter of bell at flats: 100.5mm
Diameter of bell (full): 105mm
Height of bell (top lip to bottom ABS ring): 70mm
Length of splines: 43mm
Length of shaft: 178mm
Length of Birfield: 248mm
Diameter of ABS ring: 84.25mm
Diameter at shaft bearing surface: 33.50mm
Diameter mid-shaft 31.50mm
Diameter of shaft at splines: 32.75mm
