I have a new set of marks t/c gears for sale sor # 295-305-2 305 low range 1100$ plus ship from 91345 vduemura@msn.com
This would not be a bad option if they were less expensive, but for almost the same $$, you can get many more options, and far deeper gearing multiples with a Toybox..
so what type of wheelin is he planning on doing that requires at least 100:1:?
A 2f does not need nearly as much gearing as a 22re does..
So you are planning on bashing in every single panel then?
It's a wheeler, not a DD. I don't think there's a straight pannel on it now.
IMHO, sell the 60 and get a Ftoy.
You will be happier in the end. Rock crawler FJ60's end up turning into buggies anyway.
They are not good hardcore rockcrawlers.
But, it's your rig..
I imagine it will end up as a four door pickup eventually. The vehicle was wrecked in the front before it was modded. He likes Cruisers, we'll make it work.
tell me about it I keep lookin at a Ftoys and think I can make it fit
I have around 170 to 1 when you need it its king most the time I drive in granny single low around 73 to 1 and it rocks better then most in doulbe low ... I cant say what the 420 is like on the street I got this thing up the 40 ... once and it was scary at 4 psi... I think for the cost a 420 or 465 would be cheaper and easyer ... I've ben told the 465 adapter is close to thesame size as a 203 doubler and adater if added it later
I already have plans for 4 tube doors....Next is is CRAWL....down want to keep replacing birfs every trip like now.
What are the first gear ratios for the 420 and 465?
Are you talking about using the 203 case with the stock case or just the 203?
Ratio of the 203?
What about a 420 or 465 with a 203/205 doubler?
Costs of what all these trans./tcase options are would be good if you have them handy.
The BIL needs to Crawl!
does the sm420/465 bolt up to the 2f or does it require a adapter?
My FJ60 has a stupid amount of gearing now-226:1. I'll be very afraid of breaking stuff at that amount of gear reduction and likely will use the gears to be in the 100:1 sweet spot for hard spots on the trail.
The fat biatch is an awesome off road machine. But as a true rockcrawler, they are not even close to a F toy.. And F toy's are dirt cheap..
