what aer ppl doing with the front axle yolk when upgrading early truck to disc axle?
will the flange/yolk off the 73' axle bolt onto the 78' third member or do you have to re-drill the flange?
Maybe. The spline count is the same (10) on the pinion up until 7/78 when it changes to 27 splines. Check the splines off your donor and see how many splines it has. If it is 10, then it will bolt right up. Pull the nut off your pinion and swap out the flange. No big deal. If you have the 27 spline flange, then you will need a new flange. You can get one at Cruiser Outfitters - Cruiser Outfitters.
You can check the flange patterns here - Cruiser Outfitters.
Good luck! :cheers:
It's been about 10 years since I did this, but seems like when I put a newer full floater in my '67, I just used the yoke from the old rear end and it bolted right on as the splines were the same.
if the splines dont match some vendors on here sell the flanges or you can put the late model yoke into your drive shaft and put it in backwards.you will need the correct bolts also goood luck
