The intake manifold on my 83 FJ60 cracked on one of the mounting ears/flanges. The crack ran through one of the intake ports and was visible from the outside as well as inside once I took everything apart.
I had been having some choppy idle issues and was making about 15-16" of vacuum at 4000' elevation, should be doing a touch better than that. Did the carb cleaner spray test and found the crack / leak. initially tried to patch it with JB Weld with no success.
I tore it down had the manifold welded, refaced and put back on with a new Felpro gasket set. The weld was ugly and only attended to the exterior, the crack is still visible on the inside of the plenum/runner but since I'm always pressed for time I crossed my fingers and hoped for the best.
After reinstall I'm still running horribly rough and making 15" of vacuum and get an RPM bump when I spray the cracked area with carb cleaner. I'm going to tear it down again, get opinions from a different machine shop as to whether this is even repairable and maybe try with a Remflex next go round.
In the meantime, if anyone has a spare intake (cast# 17111-61021) they'd be willing to part with please let me know. I'm due to move states again in about 5 weeks and of course this is creating another crunch.
Thanks all.
Thanks all.
