So... this particular job started out as a simple antenna replacement... having no luck getting to the antenna cable it looked and was pretty easy to pull the middle dash bezel and get at the radio, pulled the radio, etc, decided since I was in there I was going to replace all the dead bulbs while I was at it, (BTW did a search and found the part numbers for the bulbs) but...
What is that A/M slide switch on the back of the climate control cluster?
I have a 94...
Also... someone mentioned Radio Shack had a bulb that would work in place of the dash bulbs (I'm OK with bending leads around the OEM bulb bayonets) anyone have an idea what bulb I need to get? I know they are 14V 1.4 amp...
Thanks!
I have a 94...
Thanks!
