Weight of Con-Ferr roof rack for 60 series
Im not sure. i have a arb full length touring rack, its steel and its heavy, approx 90lbs. Nothing the cruiser cant handle but id make sure whatever i got was as light as possible because IT DOES make a difference on the trails. you feel the extra weight pulling you around
I’ve got one like that. About 80# max
I came across one unfortunately my cruiser power steering is out right now. I wanted to pick it up my 1995 Toyota Previa factory roof rack (see pic) and secure it down with a couple ratchet die down straps. I was trying to see if my factory Previa roof rack would hold the Con-Ferr weight
Oh yeah. Get pics!
It’s light really unless they put some heavy floor in it.
I have one left over from my 60. Without a floor it should be more like 40-50 lbs. Less if you unbolt the feet.
No flooring in it at all. Thanks for the input. Any suggestions.. I"m using 4 Heavy Duty ratchet die downs.
You know those wire ties? I’d use those and some good Plastic zip ties. Back up ratchet
My New/Old Con-Ferr roof rack made it home safely strapped down to the Previa Roof Rack. It was fairly light. Now it's time make it look good. Thanks for all the input.
