The other day I drove the 40 for a few miles and it ran fine. When I pulled in the driveway and was about to turn the engine off, it made a high pitch squeal and then died. The noise was similar to when I had forgot to cap a vacuum port on the carb adapter. I wound up replacing the gaskets between the intake and adapter and the adapter and carb because I was getting a lot of RPM fluctuation when I sprayed carb cleaner in around the base.
This did not fix the issue. She ran like hell if I screwed the mixture screws WAY out and died as I tried to adjust the mixture in. Then, wile running, I unseated the idle jet on the choke side and just a 1/2 out, it started running much better. I took it out and made sure the jet is clean and the o-ring looks fine, but it will not run with that jet fully seated. Runs fine with it about a half turn from seated.
Any ideas? This is time sensative as we have a club ride this weekend in the Outer Banks of NC.
Thanks for any ideas, or suggestions.
Ramon Weller
