Water Pump for a 1974 FJ40 (1 Viewer)
Philippines
Hi everyone,
I just acquired this new water pump for my 1974 FJ40. Am curious to know what is this small hole outside the housing and what is its purpose? Do i need to cover this?
Would appreciate your inputs...
Thanks/Philip
Spike Strip
Goblin Mode Activated
Lost Angeles
Did you buy that Pump in the PI ? Could you post a picture of the box it came in (the Label). It's a GMB, but looks a little different from the ones sold here in the States, I think.
Thanks.
65swb45
Elder Statesman
Supporting Vendor
Website
www.marksoffroad.net
Also know that the gasket between the backing plate IS NOT SEALED! Before you install it you will need to pull it off and seal it yourself.
Philippines
The "weep" hole will drip out coolant if the shaft seal starts leaking. It provides some degree of warning before the leaking seal wipes out the bearing. When the bearing fails, it often times sends the fan into the radiator.
Thank you @73FJ40 for your inputs. Appreciate your inputs.
Philippines
Thanks @65swb45 . The backing plate and the gasket looks tightly sealed but does not look like it has been applied with sealant adhesive. Do i need to use one? Tnx
Philippines
Btw @73FJ40, do i need to disassemble the Backing Plate and Gasket , then apply a sealant adhesive before tightly sealing it with a screw driver?
Would apreciate your inputs.
Thanks/Philip
Steamer
Miami, FL
It's a gamble. You may very well install it without removing and sealing it and it won't leak. I did once. And then you may have a leak if you don't seal it. I have.
Philippines
Thank you @Steamer . It looks like it is tightly sealed and closed from the factory. Am just pretty hesitant to untighten it. Tnx
65swb45
Elder Statesman
Supporting Vendor
Website
I just did mine last week, and I was surprised by how hard I had to hit it with an impact driver to get those screws loose. There was no adhesive of any kind on the gasket. :rolleyes:
Philippines
Yup. That's what I thought as well. So i'd rather to leave it as is. Thank you @65swb45 .
Hi 65swb45 , am not a mechanic but i have some basic skills of doing some basic/simple troubleshooting stuff of my FJ40. Do you think I can manage to open the back plate and be able to seal it with the gasket and adhesive sealant using an impact driver? Thanks
65swb45
Elder Statesman
Supporting Vendor
Website
If you’ve never used one before, it’ll be a game changer! It was for me.
Something like this:
Amazon product
I had never seen one until I opened my shop, and a mechanic friend (same one I mentioned a few days ago who cured his motorcycle parts in the toaster oven) loaned me one after showing me how to use it.
I never forget the people who introduced new tools to me. Never. Life is a journey of empowerment, and tools are empowering.
Philippines
Amazon product
I appreciate this big encouragement. If ever, this will be my first time to use an impact driver.
Thanks a lot master 65swb45 .
Steamer
Miami, FL
I would keep in mind you may unavoidably damage the gasket when you remove the plate. It happened to me on one but not another. I don’t believe those gaskets are available. Making one out of some sheet gasket material with a ball peen hammer and a utility knife is easy if you’ve done it before, and if it’s your first time it may take more than one try, but it’s a skill worth developing for future repairs.
Philippines
Thanks for this advise @Steamer .
This will be my first time to do it.
Truly appreciate your inputs and will take note on them.
Thanks again/Philip
Spike Strip
Lost Angeles
I don't know what's available to you if you're in the PI, but if you can get the Japan-made Koken (they call it an 'Attack Driver' in English), they come with the correct JIS driver bits. It's a lifetime tool. Koken has a few different models of the driver.
Good luck!
Philippines
Good luck!
Thanks a lot @Spike Strip . Will try to look for this brand. Most of the Japanese brands are available in PH.
Appreciate your help.
Thanks again/Philip
