Water pump and front end stuff replacement advice
Seattle
Next week, I have my 2010 LX570 w/170K going in to perform some preventive maintenance. So please let me know what I have forgotten.
1. Water pump
2. water pump pulley
3. Fan bracket assembly
4. fluid coupling assembly
5. tension assembly
6. Belt
7. Fan Pulley
8. sub pulley
9. Thermostat
I did the radiator, spark plugs, and PCV valve 20k ago
T's for the heater hoses.
As I recall, the water pump pulley comes on the water pump.
By sub pulley, do you mean the idler pulley? Good idea to replace it.
Is the fluid coupling the fan clutch? I didn't do that and don't see the point if it isn't failed.
I also did the small and large hoses, and thermostat housing (it might have come with the thermostat?) on the last one I did.
Here’s my thread on 150k baseline. I replaced most of the front mounted components. Probably went overboard but I’m happy I did this.
