Water from under dash on my FJ55
  • Thread starter Thread starter Hodag
  • Start date Start date
H
Hodag
Guest
3" of rain in one hour yesterday. Today when I moved the 55 water ran down the front of the heater. Its rainwater, not antifreeze, or any other fluid. My assumption is that there is a seal or something under the hood that is bad or gone. Anyone experience this and how to fix. I also get some water in the corners of my footwells and this I know is from the doors. The rubbers on the outside are shot. Does anyone know where I could get new ones or are there universal types that would fit. The interior is Rhinolined so its not rusting but Id like to figure this out so I can put in carpet. Thanks, Hodag
Having just gone through rebuilding an FJ55 I feel a little qualified to answer your questions. The area below the wiper grilles is perforated with the wiper pivots. We had one of those fail on us so you could check that, as well as the three bolts that hold them in. The bolts for the wiper motor also poke through there so if any of those are missing you have a hole as well. I would also check the drain from that area. There are three, one in the middle and two on the outside, make sure they are clear. You could also confirm that the foam weather stripping at the fan is in good shape and not crumbling away creating a potential leak.
Other than those possibilities you may have a rust perforation at the front windshield or a leaky window gasket.
Is/was there water on top of the dash directly below the gasket? If so that's a sure sign the gasket is gone/leaking.
Thanks Cruiser-Guy, I will definately be checking those this weekend. By the way the PO's repairs look, I probably am missing all the bolts and crap is held in with zipties. Thanks again, Hodag.
Hodag-
The door rubber can probably be bought through both SOR and Man-a-fre. I recently purchased SOR's body molding for each door opening-on sale. It replaces the molding around the door openings on the body-not the outer door rubber. Works great so far for keeping the doors tight and the weather out. I also had small puddles on my floor boards in the past after heavy rains but I think the new molding cured that. Next will be all new door and window gaskets and rubber (the ones I can find anyway :D).
Somebody posted a while back that Saab 900 weather strip would fit into the guides around the doors - haven't tried on mine yet (still under the hood) but would be much cheaper to source ;) $OR is very proud of the stuff they've got for 55's - and used is all but non-existent. I'd check out the vent for your leek as prescribed...
Good luck!
Tucker
I have a leak on my 75 PIG. My front gasket is leaking and badly weathered (original - still has the chrome). Anybody know where I can get a new front gasket and windshield? The window shop says it needs replacing to replace the windshield which is cracked. sorry, don't know how to start a thread so don't know I will be able to navigate back to this spot.
Thanks
Jim
TLCA new member
15160
