I've recently rebuilt my front axle, about 8k miles ago. A little while ago I changed out my transfer case oil and decided to check the front and rear diffs also. The rear oil was changed out about 1.5k miles ago when I installed my aussie locker and it looked brand new.
When I removed the front diff's fill plug the oil started leaking out. It was brown and looked chunky, kinda like chunky caramel. I dumped that oil and ran some other oil through it to dilute/rinse the internals out. I re-filled the housing with 75-90 redline (the same stuff I originally put in it). That was about 2 weeks ago. I just went out to check it again and the oil appears to be turning that same brown color again.
My breathers are extended. The seals are good and the birf grease is not getting into the diff housing, the diff oil is also not getting into the knuckles. I have not driven through any water. The gear oil appears to be contaminated with water but I have no idea where it could have come from considering i haven't driven through anything deeper than standing water puddles.
Would a bad 3rd member destroy the oil like this? I've been having an annoying whirring noise coming from the front end and now I'm thinking it is caused by a bad differential and not the ds/ujoints (which I've already had re-built).
Anyone have any ideas for me? I'm now planning on swapping in the replacement 3rd I bought a while ago, I've just been putting it off because it's a pain in the butt.
Thanks for your input.
