beanz2 said:Ross, does the Dyna have an identical tray to a 75 cruiser?
Dave
roscoFJ73 said:I also saw this cool trailer and now I want one
It kinda looks Dynarish but it has a 4wd badge??
beanz2 said:I think it refers to the electronic controlled 1HDFTE only. Australia stopped getting the 1HDT in 1995. It's too ancient for them
Dave
Tapage said:I'm not dreamed drive a Troppy with the 210 HP 1HD-FTE not yet .. but I can imagine drivin it on a mud trail in 3rd gear .. both factory locker engaged, spining tires very hard .. wooooouuuu fantastic .. !
roscoFJ73 said:There was a long distance road test on an identical blue troopy in Aust 4WD monthly early 2005. They took it through the desert and it got a full 10/10
Pity it costs the same as a new Mercedes![]()
Tapage said:other question .. why this spacer between tranny and transfer . ?
beanz2 said:The R151 is based on a light truck/passenger car design where the shifter sits external to the main gearbox in a rear extension of the body. Since the BF1A split case was designed for a Land Cruiser, I guess Toyota needed to put the transmission shifter in the extension
Dave
Tapage said:but I thought those troopys are considered by Toyota as heavy duty ( half ton ) truck, so they need H151 not R version ..
Tapage said:Thanks Dave ..
ideas, if the AX15 have the same bolt pather that R151 and H150 ( I htought those boeht are diferent than H151 )we can easy bolt 4.0 6L Hight Output engine to a R1515 in a Toy .. ?
And the same .. someone that have a 4.0 HO j**p with a AX15 can change easy to R151 tranny ( that I supose to be more stronger than AX15 )
Tapage said:ideas, if the AX15 have the same bolt pather that R151 and H150 ( I htought those boeht are diferent than H151 )we can easy bolt 4.0 6L Hight Output engine to a R1515 in a Toy .. ?
roscoFJ73 said:What about the imput shafts?![]()
I busted that little jigger on my 78 Troopy, I thought it must be a little filter, do you know what it does?roscoFJ73 said:Some more pics underneath and around the troopy. Beanz,thats the valve thingy that gasser 73 series dont have. This one is fitted to the subtank
OOOH they are so shiny![]()
beanz2 said:It appears to be a one way valve for a vent for the tank.
Nice 78, Stu
Dave
