Couldn’t find a definitive answer searching and Slee has never installed one... so has anyone installed a Warn zeon 10-S in your ARB winch bumper? If so did you need the ARB spacer kit or any other tips? Thanks!
I ended up ordering the VR10-S today. What spacers did you use? I ordered the ARB spacer kit as well.Not the same winch but I have a Warn VR 10 and I needed almost an inch of spacers. It is a super tight fit in the ARB.
I actually just made my own spacers. Just got 1/4" thick 1" wide steel strips and cut a few squares. Drilled a hole in the middle and called it a day.I ended up ordering the VR10-S today. What spacers did you use? I ordered the ARB spacer kit as well.
Thanks appreciate it! Good call on bolts... post some pics when you can.I actually just made my own spacers. Just got 1/4" thick 1" wide steel strips and cut a few squares. Drilled a hole in the middle and called it a day.
I will post pictures as soon as I can. Don't forget to buy longer bolts as well. I used 10.9 class M10-1.5x70mm but they were a tiny bit too long. 60mm would've been better I think.
I remember cutting down my 70mm bolts at least 10mm so I think 55mm or 60mm is the way to go.Thanks appreciate it! Good call on bolts... post some pics when you can.
Thanks... wondering if I should get the M8000s and call it day now... LOLI have a zeon 12 behind my arb bumper with extension wires taking the contactor up by the second battery. I had to use a lot of spacers. I remember depleting my junk metal pile and buying commercial ones on amazon.
Might be the move honestly. IIRC the M8000 fits with no spacers or any other funny business.Thanks... wondering if I should get the M8000s and call it day now... LOL
