- Location
- United States
Warn 8274 winch that I just rebuilt. The winch was completely disassembled before the case was soda blasted. The internal gears were all cleaned and inspected before reassembly. All new bushings and seals were used in the lower case, using genuine Warn parts. The brake assembly is also completely rebuilt, again using genuine Warn parts.
The motor was completely taken apart, cleaned and inspected before reassembly. Each solenoid was cleaned, inspected, tested and treated to new hardware before reassembly. The cables from the solenoid pack to the motor are all new. The remote plug is new as well. There is a crack in the upper corner of the solenoid cover.
The winch was bench tested and powers in and out with no problems. The free spool clutch assembly was also rebuilt and moves in and out freely.
I can also remove the cable, motor, solenoid assembly, etc. if you just want a rebuilt core to add your own parts to.
Located in Little Rock, Arkansas.
$750 shipped to the lower 48 states in the USA.
