Wanted Wanted - Tool bag tie down hooks for 1979 FJ40 (1 Viewer)
Hi. I'm looking for the tie down hooks for the tool bag strap for my 1979 FJ40 (under right rear jump seat). Thanks.
Thanks for the reply, Unfortunately, I don't see any of the hooks I need in your picture. If you have others, please show. Thanks.
i have NOS ones , PLEASE SEE EACH Link below :
thanks matt
2 of them are spot welded to the body (behind the bag in the picture) and body colored. The front one is attached by a bolt and is cad plated. Are you looking for all of them? I may have the attached ones.
Good morning. I'm really looking for all 3 of them. Do you only have the ones that go behind the bag?
thanks matt
Thanks, Matt. These are for pre-'79 rigs (as i'm sure you know). Will keep in mind if i don't find exactly what I'm looking for.
can you please PM me exactly what your looking for ?
i have many others not listed in climate control storage too
thanks
Nope don't have the front one. I have the rear ones but they are still attached. I don't have a tool bag and don't plan to get one. You might want to check around some more. I am willing to part with mine but it would have to worth my while to cut them out and then fix my fender. There are 2 spot welds on each.
thanks
Bag location and front hook set up changed for '79 and later. Please see photo attached in my original post. For '79+, thee is no front metal hook attached to band. Band secures directly around a hook welded to tub.
welded to tub ?
or
bolted to tub ?
i have never seen a spot welded tool or jack retainer rubber band hook before ?
welded to tub ?
or
bolted to tub ?
My picture above shows how it came from Toyota. The rear two are welded to the tub and the front one is bolted with a little raised lip in the wheel well to help position it. The late tool hold down bands are just a loop of rubber, no attached clip.
Looks like the older clips (not the one on the band but the others) are the same as the late clips.
i like mud because u learn something new and exciting every day
thanks
