Wanted Wanted: 2F parts
cruiserbrett
GOLD Star
Washington, DC
Wanted: F/2F parts
I need a few things to finish up the parts hunting for the next 2F I am building...
FJ60 lower radiator pipe. the one that goes between the radiator and the water pump on an A/C equipped fj60.
2F water pump pulley for 2F without fan clutch(75-78 FJ40/55 would be good donor).
Alternator pulley from F/2F engine. just needs to be wide groove like any cruiser would be.
cable gas pedal assembly for an FJ40(68-73)
FJ40 heater pipe that mounts to the lifter/pushrod cover above the distributor(should be about 12" long)
F engine valve cover nuts-the 4 acorn style ones
If you've got some of the list above, please let me know via PM or email.
thanks,
-Brett
brettgarland (a) yahoo.com
EDIT: new stuff added
I could have sent you a FREE alt arm with the box I just sent Dominic. Oh well.
Arm is free nonetheless. Hit me up next week when I get back from DV and we'll work out the details.
I have the other parts as well, if you dont work out another source.
Mark A.
i may have that oil filter mount... got an exact pic? SOR catalog, etc...
malphrus
number 3 in this picture.
It should have a 1/8" bspt threaded hole or possibly may still have a oil pressure sender attached...
If Malph's doesn't work I have one. It does NOT have the sensor still attached.
i'm goin to pass if you have one on hand... that part, if i have it, is at the way back, way bottom of the boxes of parts i've got, ha ha.
malphrus
I have
I have water pump pulley, fj40 heater pipe. I will take pics tonight.
Ryan
Brett, I've got a 60 lower pipe,water pump pulley, alt pulley, is the heater pipe the same 40's and 60's, I've got some of them also.
Paul
Paul,
there are a few versions of the heater pipe. some brass, some steel, some long(double "L" bend to lower rad hose fitting)
Ideally I would like to find the short brass one. these seem to be early 2F vintage.
Here is a pic of what I need on the other 2F I am working on right now.
Brett, I've got one of those off a 79 block, it's metal tho, not brass. Paul
