Wandering on rutted roads (1 Viewer)
Sisters, Oregon
I have a 78 FJ40. It has always darted all over the road in ruts. I replaced 32 X 11.50 15 inch BF Goodrich TAs with some new 32 X 11.50 15 TAs. It darts when it gets in the ruts in the road. I have recently replaced the bushings in the shackles and I inspected the other ends of the leaf springs and they are in good shape. I had the front end aligned after the new tires were installed. I see a lot of new Jeeps around here with the same tire combination and they handle the ruts OK. I like the look of the wider tires but the wandering in the ruts is dangerous. Any one have a solution?
A10Driver
Do you have a lift, if so you may need to correct the caster with shims (get the steel ones). If no lift then I would check the toe. Should be 1/8" toe in.
Sisters, Oregon
I have about 2" extended shackle lift. I know the toe in was OK but I am not sure about the caster. I will talk to the alignment technician tomorrow. What kind of caster reading should I be looking for?
AussieHJCruza
New South Wales, Australia
I'd get a caster reading, would suspect it would be in the negatives which makes the drive "exciting" in a bad way - once you get that you'll be able to work out if shims will work to fix or if you need to do a cut and turn. If it's only 2" shackles I'd say shims will be suitable
1911
chupacabra
Parker County, Texas
A word of warning: many alignment places today have never seen a leaf-sprung vehicle and don't know what to do with them. They probably just blew off the caster because they don't know how to correct it. You need to go to an old-fashioned spring and/or frame shop that knows leaf springs. Most large cities still have at least one.
