Wandering Cruiser (1 Viewer)
N43.875, W121.455
Ever since the lift (OME tbars, 866 springs, slee diff drop), the cruiser has started wandering. More specifically, it pulls to the right with power and on-center track is vague. Taking off from a light with intermediate throttle I have to hold left pressure on the wheel. As soon as I let up the truck will pull left unless I release.
Truck tracks straight with braking no matter how hard, so I don't think it's a UCA/LCA bushing issue.
I have a slight rake (maybe 1/2") wondering if perhaps lowering the front a bit more will help? I have not yet checked if rake is equal left/right.
Truck has 79k on it. 295/70R18's on Tundra wheels. I don't feel any bearing play up front.
Any thoughts/suggestions?
Edit: Alignment was done after lift. Was way out, now within spec. Haven't touched t-bars since.
2000UZJ
Where's My Hammer?
Earth
Lower the front end. My 100 was rather "twitchy" at highway speed, fast lane changes were another story.
N43.875, W121.455
Just checked and the rake was nearly neutral on the DS, about 1/2" on the PS. It was equal when I first set it up...must have settled. So I lowered it to 1/2" on the DS to match. If that doesn't cure the problem then I'll start taking down both sides equally in 1/4" increments.
N43.875, W121.455
swap the rear springs side to side?
I had a similar issue with 865s, and when I put the Slee 2RHs in it fixed it.
I'm thinkin' it's the front, but I suppose there could be an issue with rear squat as well.
Off topic, but are the OME 725's for real? 1300 lbs load increase for the 200's? Those things must be rocks.
hoser
Bay Area, CA
The official caster spec is:
3.08°±0.75°
I could not get mine within spec post lift... 0.4 and 1.6 at best.
N43.875, W121.455
Interesting Hose. I had assumed that Les Schwab had the correct numbers in their book. They actually show the opposite: 1.0 specified with a range of 4.0. I'm at 1.3 left, 1.4 right.
I just looked it up in the pdf 2004 FSM that I have and it shows 2.5 +/- 0.75. Does this vary by year?
Regardless, a low caster number would definitely explain the wandering.
N43.875, W121.455
To add to this, I've noticed that my wheel doesn't center very quickly coming out of a tight corner, particularly when on the gas. I had attributed this to the FT 4WD, but now that I think about it, it's probably the caster (or lack thereof).
hoser
Bay Area, CA
Well, there is probably more to it than that... when you lift the vehicle, you get more weight transfer. Upon acceleration the front lifts up a little more than usual, the rear squats more than usual. And the further your suspension arms and steering arms are from horizontal, the more toe change there will be... and hence less likely to drive in a straight line.
Toyota engineers had all the suspension/steering all dialed in... and then you came along and change one variable (lift) and screwed it all up!
I'm thinking about dialing in a little extra toe-in on my next alignment to compensate for the extra deflection with taller tires.
N43.875, W121.455
I don't dispute your theory that the lift threw Mr. T's hard work out the window. However, if anything there should be less squat now with the 866's in the rear, right?
I'm thinking that I get the t-bars equaled L and R, get the caster back up to as close to spec as possible (per advice here), and - as you also suggested - dial in a little extra toe to help compensate. Good idea!
