Some spring cleaning. One picture of each item included, but can provide any others on request. Prices are best I can figure based on seeing what others have sold for. Shipping not included in the price.
Pictures:
1 | PTO gearbox from a 72 FJ40 (sold bmoonhajjar) | 200 |
2 | Knuckle/hub rebuild gaskets, shims, one seal (sold hyhype) | 10 |
3 | 72 front and rear drive shafts | 50 each |
4 | Bellevue Warn winch 8000 (pending NorCalFJ100) | 150 |
5 | rear barn doors (sold pg498) | 100 |
6 | rear tire carrier and latch (sold pg498) | 100 |
7 | Warn hubs and rebuild kit (sold hyhype) | 75 |
8 | Voltage regulator | 10 |
9 | Caliper hardware (3 sets) | 5 each set |
10 | drum brake springs | 15 |
11 | OME rear shock bushings | 15 |
12 | 3FE AC Compressor | 75 |
13 | Clutch master | 10 |
14 | FJ40 brake booster | 75 |
15 | FJ40 brake line shield | 10 |
16 | FJ40 radiator | 100 |
17 | Drum brake bleeder screws | 10 |
18 | 3FE MAF | 50 |
19 | set of bump stops | 10 |
20 | Steering gearbox mounting bracket | 25 |
21 | FJ40 gas pedal carb linkage | 75 |
22 | FJ40 gas pedal | 25 |
23 | brake master | 20 |
24 | 3FE/FJ80 backing plate | 50 |
25 | 3fe FJ80 motor mounts (sold) | 20 |
26 | FJ40 tail light guards | 30 |
27 | 3FE block heater cord | 10 |
28 | 3FE air intake tubes | 25 |
29 | Shock pins (sold JDNs78FJ40) | 5 |
30 | fj40 hood hooks | 5 each |
31 | fj40 rear view mirror, no glass | 5 |
32 | fj40 mirror arms | 25 |
33 | fj40 door handles | 15 |
34 | fj40 hood support rod | 20 |
35 | 3FE Smog system (if buying numbers 36-41 as a set) | 150 |
36 | hard vacuum tubes | 20 |
37 | EGR | 50 |
38 | air rail | 20 |
39 | air pump | 40 |
40 | air pump bracket | 30 |
41 | vsv's and brackets | 50 |
Pictures:
