VSV wiring harness part search help (1 Viewer)
In a van down by the American River
I have an electrical connector that is frayed and ready to break on the connection to VSV (blue connector). As part of my HG replacement I want to fix before I wrap up the intake reinstallation. Does anyone know if just the pigtail harness is available? This same harness also connects to the other valve with maroon connector. Thanks
Look at the connector closely and find the 5 digit number. Google that with pigtail and you should find some options. There's an electrical connector service manual around here somewhere that has the correlating pigtail part number if you want toyota oem.
Also go to a junk yard. Camrys have the same connectors on their vsvs. They are real easy to get to they are right under the top engine cover. Just bring your vsv to match it up.
Thanks! Found a few numbers that helped track a connector down.
If anyone is looking to replace the blue VSV connector you can use Dorman 645-673 pigtail. It’s use for a side marker light but the same connector.
