VSV Queation
Discussion in '60-Series Wagons' started by Toadhopper, Jul 25, 2005.
  1. Toadhopper
    Toadhopper
    686
    4
    May 19, 2005
    Is the VSV responsible for bumping up the idle when the compressor turns on?
    If so, is the amount of idle that it bumps up adjustable or preset?
    Toad.
  2. soggy60
    soggy60
    844
    5
    Nov 16, 2004
    Adjustable....
    VSV in on firwall by smog valves...
    Pull-up dashpot is on 'front' of carb.
    follow linkage to throttle shaft, you'll see adjustment screw...
  3. dogboy2
    dogboy2
    996
    9
    Jul 8, 2004
    Portland, OR
    Toad,
    I assume we're talking about the AC compressor?
    If so, there is a blue, rectangular shaped box with a circular dial on the face located underneath the dash panel near or around the glove box. It's roughly about 4"x3". IIRC, the dial regulates the vacuum advance when the AC compressor kicks in. You can adjust the amount by turning the dial, in turn, adjusting the idle speed to compensate for the additional load when the compressor is running.
    HTH,
    -dogboy- '87 FJ60
  4. chitown40
    chitown40
    2,112
    24
    Feb 9, 2004
    Buffalo Grove, IL
    Linkage on the carb controls the a/c idle-up. VSV activates it. Blue box (a/c amplifier) controls the minimum RPM that the compressor will engage at.
  5. dogboy2
    dogboy2
    996
    9
    Jul 8, 2004
    Portland, OR
    i must be getting old(er) ;)
    thanks for the refresher course chitown,
    -db-
  6. chitown40
    chitown40
    2,112
    24
    Feb 9, 2004
    Buffalo Grove, IL
    No problem db. I probably learned it from you in the first place. ;)
  7. Toadhopper
    Toadhopper
    686
    4
    May 19, 2005
    Vsv
    THANKS Everyone!
    Toad
