This is mostly directed at @torfab and @orangefj45 but wanted to post it up for anyone else with the same questions as me. I have a ballpark idea of what to expect to spend on the conversion from Valley Hybrids / Cruiser Brothers and I'd be surprised if Torfab's cost is different by much, so I won't be discussing pricing or cost here.
As it turns out, I may be coming into some money in the next year or so, and if I do will be jumping on a Vortec conversion. It seems the favored engine is the 5.3, but I'll be going for the 5.7. For a while I had been thinking 6.0, but cost of aquisition, maintenance and overall availability led me to think the 5.7 is a much better option.
So my first question is about diff gearing after the conversion. Georg had told me a while back what transmission is typically used for the conversion, but I've since forgotten. Not knowing how the transmission is geared, I'm curious what the ideal diff gearing is for a 5.7 running 33" tires that would see about 70% pavement/highway and 30% trails (no rock crawling). Be great if the factory 4.11 gearing of a 62 could be used. Be one less step needed for me to worry about.
Transmission? Do GM transmissions usually run as hot as Toyota trannies, hotter, cooler? Regardless, I plan to keep my external cooler installed, so hopefully the GM trannies at least don't run any hotter than the A440F.
I'm told that the Toyota split case is retained and an adapter is used to mate it to the transmission. This would be awesome, and since it would be torn open in the process I'd opt for a full rebuild, McNamara gear and one of Georg's twins stick kits.
Suspension? Before I get into a conversion I'm planning to have done an OME 2/3" install, using heavy/heavy springs. The small block is not so tall of an engine that this wouldn't accommodate it is it?
Exhaust? Is a dual exhaust typically the solution? If it could fit under the truck, a dual 3" exhaust would be awesome.
How about gauges? If the OEM gauges are not retained, I imagine that would be a great opportunity to convert over to the Speedhut gauges.
I'm sure there are more questions I'll think of later and that others will think of and post, but this is all I got for now.
