do i need a voltage regulator on a chevy 3 wire alternator in a 74 FJ40 with a carb'd 350 (the 350 is a 74 with an HEI dist).
Note: This feature currently requires accessing the site using the built-in Safari browser.
not really labeled the alt has a post in the back with a nut on it. which i assume is batt. then a red and a white wire, that go into a two prong connector (which can only go on one way. the red wire i have connected to the ignition and the white going to a ground.
