9/74 FJ40 - Does the tag wire off of the Voltage regulator connect to anything. I have all of the wires labeled but none labeled for the voltage regulator other than the large three wire set with the connector. If it does connet to one, what color wire would that be.
Ran into almost the same problem with the starter. When looking at the starter with the engine on the right, which spade connection on the solenoid takes which color wire. There is a black and yellow and a black and white.
I have a wiring diagram but could not definitively tell what went where.
Thanks
Thanks
