Greetings and happy thanksgiving to you NA folks. I have an FJ62 that recently had a reman toyota oem alternator installed. Recently I noticed that when either the windows are the whole way up, or the whole way down, when you push the window switch in the same way the voltmeter in the gauge cluster pegs at the lowest amount. I havent put a real volt meter on the car yet but prior to getting dirty I figured I would ask the brain trust to see if this is something that is normally seen. I figure it might be a ground or something or possibly the gauge in the cluster is just buggered.
Thanks in advance!
Casey
Thanks in advance!
Casey
