VintgeTEqParts FJ / BJ / HJ 60 / 62 Series Technical Solutions ........ (6 Viewers)
We also got into and a bit more then Dabble in the Restore Topic of parts as well :
- i have been restoring 40 series pull switches all my adult life and , now comes the time to evolve that skill set into the 60 series
- From a pile of 1980's Rubbish .......... :confused:
- can become the " Treasure of Oak Island " :D
For some time now i have become VERY Frutraated with TOYOTA Corporate in JAPAN
as they continue to Dis-Continue Needed Parts For ALL Land Cruiser's ALL years
well ...............
Below are 2 Examples of what i both decided and then engineered 2 similar needed
parts solutions , using a array of NON-USA similar but indeed compatible 100%
TOYOTA Genuine Parts , Made in JAPAN ....
- Combined in a Very Thoughtful way to help meet the Need's of the 8/87-9/87
40/ FJ60 Communities in there time of this VERY Common Needed Parts Solution ....
note : these also fit 8/80-Later FJ40 w / 2F
- Alternator Drive Belt Adjust Tensioner Kit
- Smog Pump Drive Belt Adjuster Tensioner Kit
IIRC, there is also a ground bond that came off my xfer and mounted to body
Yes, to aid with the reverse light (on manual transmissions) and the 4wd shift light, in case you don't get enough current through the bellhousing and transfer bolts.
A recent addition we have added , is our 2F Engine AIR Cleaner Box / Housing
Seal Up & well......... Cosmetic Dress Up Kit also ....
My wife actually suggested making the air cleaner on 2F's look like a million bucks
Because its the first thing u see when u pop your 60/61/62 Series Bonnet or ...
Hood .
who the h#ll ever started calling a hood a Bonnet in Japan anyway ? 😆
Our Kit contains the Following 100% OEM TOYOTA Genuine Parts :
- Carburetor AIR Horn Gasket / O-Ring / packing Seal
- a New shinny Silver Zinc Carburetor Mounting Stud .....
- 3 Rubber Seal equiped special OEM wing Nuts
( Yellow zinc LIVES ! )
- qty x 4 Air Cleaner 8mm x 1.25 x 16mm long Yellow Zinc SEMS Bolts ,
w/ a nice and wide fender washer on them , way way better then the original stock ones , this is a specific area of Focus , and where using a Unique and better
Needed parts Solution make 100% perfect Teq Minded mechanical sense in every way ...............
- 1 for front of cover near radiator ,
- 1 for rear of air box fire wall
- 2 for where air box bracket bolts to the side of the cylinder Head
- If anyone has a air box with More the 4 mounting Bolts 12mm hex
please PM me , i will make the adjustment and ship extra ones at NO additional cost ....
- i have seen more then one 2F Oval air box slightly different variations ,,
- we Also keep in-stock at all times , OEM Air Filters , these are the exact Air Filters that come in a expensive TOYOTA red parts box from tyhe dealer ,
but in the OEM parts maker Nippon-DENSO own Store brand private label box
for a fraction of the Dealership one , You simply Pay MSRP of $27.95 as of 4/7/2020
- we , well .....................are Less :)
- the new Carb Stud is the real unicorn part in the kit in my opinion , because
after years on on and off by PO;s who don't know , and Rough treatment by
Over worked and Under paid TOYOTA Dealership Service Techs ....
that carb. stud has male threads all buggered UP like trashed bad !
so , NEW OEM is the Only logical choice and a nice feature of the kit we
put much care and concern thought into developing for the FJ60 2F folks out there , and also our 1/75 - 1984 FJ40 Friends Too ...........
- If anyone has additional ideas or feedback on any additional parts or items to include in this one of a kind Plug and Play Kit Format , please PM me your ideas and thoughts ............Please
- we Listen to our Valued Clients and Friends in the land cruiser community when it comes to this topic
thanks
matt
Here is the Direct Link To The Air Cleaner Dress up and sealing Plug and Play Kit ...........
- And the DENSO OEM Air Filter Element .............made in JAPAN of course
Received this yesterday along with a new air filter and it looks fantastic.​
Extremely happy!
Received this yesterday and it looks fantastic.​
Extremely happy!
Did u receive the 4 Yellow Zinc Air Box Hold Down Bolts 12mm hex too ?
i only recently added them to Upgrade and Bling out ,the kit more ...........
I’ll have to got back and check. I just cracked open the box to admire the beauty. Also appreciated the extra swag.
If you missed the 4 Yellow ZINC SEMMS Bolts upgrade Boat ?
I got your Back , i will send them out right away , no worries ............. :)
Putting some Deep thought into the little thing in life that can get really annoying ?
And Always Using and Applying Toyota Genuine OEM parts of Course :cool:
This next topic has become a thorn in my side before , well now no more .....
The 8/80- 1990 FJ60/ FJ62 Hood Prop Rod Retainer Clip and Rubber Pivot Grommet Repair & Restore / Preventive Maintence Kit........
The SEMMS Bolts were not included in my order. Great customer service shipping these after the fact. Also the rear washer bag I ordered is perfection. Always a treat to get new OEM quality parts for a 33 year old 60.
Very Cool as usual.
Can you comment on the feel of the tape compared to Tesa High Temp Fabric Tape?
Your picture of the tape makes it look more plastic vinyl type.
My FJ62 is suffering from electrical gremlins with no obvious culprits. I'm thinking about just replacing runs instead of trying to figure it out ... my father was an electrical engineer but that s*** just baffles me. I'm not finding a website for ToyotaMatt. Where should I look please?
