VintgeTEqParts FJ / BJ / HJ 60 / 62 Series Technical Solutions ........ (7 Viewers)
One more Q about this part - if in down position, do you still get alright FM reception?
Not likely. With FM signals you need an antenna that isn't surrounded by sheet metal (our fenders) that creates an essential faraday cage. FM frequencies fall within the VHF spectrum and you want an antenna that reaches as high above the vehicle as possible, within reason. With the antenna retracted into the fender, you'll only get reception from the absolute strongest signals where you're located, and even those will be fairly weak.
if down
your reception range is really NOT that good .......
AM
or
FM
I keep forgetting that some people still listen to AM.....
in 60 seconds or less DAN ,
please explain what the Abbreviations
FM and AM stand for ...:idea:
NO cheating like google ,,,
im a TEqJedi and i WILL know if you did ............ 🤔
Amplitude and Frequency Modulation.
It refers to how broadcasters encode the signals before transmitting them.
I also rarely listen to FM stations because they have more commercials than potato chip bags have air, and even less often to AM.
And you do realize I don't use push notifications for anything aside from texts and voicemail, right?
i can't get my MUD push notifications to work ...... :confused:
i have never seen a total plug and play ALL FJ60 ONLY washer bottle , all inclusive ?
- i even found the pump grommets with the filter screens in them !
so i pipe-dreamed one up .......
Damned impressive there.....
Something NEW and Wikied This Way Womes : Genuine SKUNK-WORKS Part # 22251-61010
FJ62 / FJ80 3FE AIR FLOW METER Repair Connector Plug Harness Side Kit
Comes With 3M Marine Grade Heat Shrink Butt Connectors Also.....
i am diving ever deeper into my fascination with all the old-skool variations of heater Union Hose Bibs
- my goals here are to Eventually find the perfect interchange / Substitute / up-grade / or simple repair remody for the Current set-up on a late Model FJ40 / FJ60 2F
- those don't last forever and a viable solution sorted out now in advance , is my Mission Statement ...........
What is the od of the threaded end on those heater unions, Matt? Looking for something to replace the iron pipe (po solution) on my Stout head, which looks pretty similar to the F head openings.
it's a Pipe Taper JIS
the very end tip is : 20mm OD
the section is : 21mm OD
1.75 METRIC Tread Pitch
these are EXACTLY the same as a 1962-1990 F , F1.5 , 2F , ( 3F carb 3FE if they have the service ports )
HOSE BIB is 16mm / 5/8"
if this is TOO LARGE ?
i have stuff 1 size spec. smaller
same threaded port with a 1/2" hose BIB
and
smaller Threaded Ports too
let me know how i can help :)
i also have this and these :
same as a stout i believe ?
are those manifold female threads M8x1.25 ?
these are the Cat's MEOW
:cat:
