VintgeTEqParts FJ / BJ / HJ 60 / 62 Series Technical Solutions ........ (2 Viewers)
Updated Goals / Mission Statement :
- Reproduce the original FJ62 Fusible Links
90982-08251 , and UPDATE it to a ALL WEATHER Sealed ARCTIS SPEC. / SNOW VERSION Concept package parts
option that WILL be tough as nails , far out-last its OLD NLA Part # / DISC. status to a NEW and improved SUPERSCEDED par
t # 90982-08252
- Hand made in-house Exclusively by the Rising Sun Mechanical SKUNK-WORKS Staff to let alone meet old factory spec's but NOW far exceeded them in every way humanly possible ...
- water and battery acid sealed resistent Laboratory Crimp connections points
- PRE-Lubed with FULL Synthetic marine grade di-electric grease for a PLUG and PLAY worry free installation
- update both primary Connector Housings to UV GRADE japan spec. ones ......
- Lengthen all the links wires , by a needed minimum ONLY amount to reduce and eliminate the traditional 90982-08251 straining / pulling stress that links wires to eventual failure , without sacrificing the overall circuit protection value at all in any way
- now officially a Rising Sun Mechanical Skunk-Works Laboratory Brand parts offering , supersession to
part # 90982-08252
thanks for your support and continued input and feedback on the ever growing needed FJ62 reproduction parts solution
kindly matt :)
I wanted to and always do want to give land Cruiser owners across the board the
Highest Quality , most well thought out and very much intentionally OVER-ENGINEERED
products i possibly can , and our new Line of FJ60 Battery Cables Will be no different !
I realized a while ago that TOYOTA had Discontinued ALL 60/62 OEM battery Cables
So , i saw a opportunity to put what i Learned during my Tenure In the T-TEN Program
and apply some good old USA TOP SHELF MARINE GRADE parts in the mix too ,
to create a set of related Products that Exceeded Toyota OEM Specs in every way , and
More importantly would stand the test of Age , and Time !
Now 8/80-9/87 FJ60 Owners will have a Choice between Pep Boyz , Rock Auto , and
100% Made in Japan parts , and also ANCHOR marine grade industrial Parts Combined
in Harmony in the form of Battery Cables Both positive and Negative , ones ,
including the little know about Starter Ground Strap called Cable , Bond No. 1............
Hi Matt,
Would this be applicable to the Vortec Swap I'm doing? Sorry for my ignorance. The kit you have would work for going to the GM starter etc.
Hi Matt,
IF .........
the location of the VORTEC starter was on the same side of the ENGINE as the 2F or 3FE and attaches to the bell housing location like a land cruiser starter .
then YES , the positive B+ cable kit would work good , i make them a bit longer then my OEM JIGS i make them to
- now the NEG cable kit ,,,,,,,
HELL YES it will work , :D
and you will have freedom of choice where to locate it as well
- so .....
we have one YES and one maybe
after u compare starter location APPLES
thanks for the good solid TECH question
it had me thinking for sure
kindly
matt
IF .........
- so .....
kindly
matt
I'll check that out and if it will work, I'll get a set from you Thanks. I'm only at this stage right now.
- if anyone can help here on this topic below please PM me , thanks ......
Several UNICORNS found there way into my pasture ........ :cool:
I sent a message on your site - there's an antenna listed for the 62 - is that the power antenna? I need one and hesitated to order until I was confirmed it was the right part
Im ready to buy if its the retractable and I can put it on my 88
- that's a NON-USA Saudi-Spec. destination market Extended / LONG RANGE Aerial
- it's about 10" inches longer then the power antenna / hence the longer range , designed for remote desert location use in the middle east by military , commercial and who ever may need it for that ..... :)
- i stainless steel construction , will never RUST
- it is a MANUAL antenna
- it indeed YES telescopes / YES fully collapsible / fully retractable
- NO Mods / direct bolt in
- 100% made in japan parts
- i do not have any power units , there long since DISC / NLA / i have not seen a new // nos one available anywhere in over 10+ years
does this answer all your questions ?
if not please let me know ?
thanks
matt
This is my personal 10/88 FJ62LG-PNEK
The GHOST 👻 sports this same exact long range aerial that you show the link to in your thread post quote above
I like it and it receives FM stations. from
Further away then the old aftermarket antenna did that was on it when I bought her several months ago
It obviously Goes down fully I am just showing you it telescopes / retracts as you inquired about
Thanks for reaching out
Matt
Matt
View attachment 3155583View attachment 3155584View attachment 3155585
You just retract or put it up by hand?
you pull it up by hand
you push it down / to retract it by hand
its a manual retracting / manual telescoping toyota genuine parts antenna
does this help you understand better my friend ?
let me know how i can further help ?
kindly matt
  • Like
Reactions: HMP
kindly matt
Matt, I'm lucky enough for my 62 antenna to still be in operating condition. I also have an 88 4Runner with a broken/blown antenna. I'm hoping Toyota made these the same? Can I put it in the runner?
kindly matt
One more Q about this part - if in down position, do you still get alright FM reception?
