TCSTARK
Master Debater & Cunning Linguist
Ok, so I got through alot of the install today and I have a few electrical questions . They are:
1. What direct ignition source did you tap into? This is the purple wire in the Vintage AC install document.
2. The evaporator unit connects to the compressor with a blue wire and adaptor. They gave me the adaptor but they are both female ends. Do I simply buy the correct one at my local parts store?
**EDIT** Been thinking about this one and re-read the electric schematic and found my answer. Both ends go into the compression safety switch and not an error on the VA kit.
I also have a question about the belt size. What size\width belt did you use? Part numbers would be ideal.
