Vibration
Discussion in '40- & 55-Series Tech' started by aircrew, Feb 16, 2009.
  1. aircrew
    aircrew Beer sipping, Toque wearing northern brother
    348
    Albums:
    1
    9
    Jan 18, 2007
    Calgary, Alberta
    Hello Everybody,
    In my 89 hilux ln106 I have had a strange vibration latley....
    See if this makes any sense to you guys:
    -Happens only in fifth.
    -At 2400 - 2500 RPM, Tried shifting into fourth and driving at the same speed... no dice.
    -No other RPM or Speed.
    -Does not happen in Neutral.
    -Sounds like it comes through the shifter, and seat, but not particularly one side, both and from the rear of the truck.
    -About 3-5 beats per second, does not sound like a tire.
    -quite loud...
    -Checked all U joints, one is a tad loose, but I mean very small, maybe a 64th of an inch movement. All others are good.
    -Steady bearing moves up and down about a 1/4 of an inch, very sloppy.
    -My rear Spline pukes grease... Grease it daily and still takes like 10 good pumps of grease.
    -Output Plate has no play, tightened that about 5 months ago.
    -And last but not least, sound goes away if I let off the accelerator pedal, and comes back when I push the accelerator again. Driving me nuts, and I don't want to damage anything.
    -Rear Diff, Front Diff, Transfer Case, Tranny all have correct amount of oil.
    -Joints are grease.
    -no loose bolts....
    Does it matter how the rear drive shafts are bolted to the tranny and diff? Are they supposed to be offset?
    Think it might be the Steady Bearing????
    Thanks
    Brodie
  2. grant5127
    grant5127
    5,025
    18
    Oct 31, 2003
    Meridian,TEXAS
    Sounds like your 5th is fixin' to grenade.........
  3. Rocky_LC
    Rocky_LC
    1,568
    52
    Sep 16, 2002
    Tucson, AZ
    Comments...
    Maybe you are missing the end cap on the driveshaft, and it's just spinning out? Maybe it doesn't need 10 pumps of grease daily?
    Do you mean offset, or "in-phase" (U joint yokes aligned). They are supposed to be in the same orientation.
    I don't think either will cause your vibration, though. Good Luck
    Rocky
  4. Coolerman
    Coolerman SILVER Star
    6,283
    Media:
    2
    Albums:
    1
    1,339
    Jan 5, 2004
    Paint Lick, KY
    Call me ignorant, but WTH is a steady bearing? :confused: ;)
    Regardless, if it has a 1/4" of slop, somethings not right...
  5. wbb72fj40
    wbb72fj40
    180
    Media:
    1
    Albums:
    1
    Nov 21, 2008
    Ramer Alabama
    I am assuming he's talking about the hanger bering. witch should have play it is surounded by a rubber grommet that let's it move.
  6. aircrew
    348
    Albums:
    1
    9
    Jan 18, 2007
    Calgary, Alberta
    Wow totally forgot to respond! It was the steady bearing... or hangar bearing... also happened to be s***ty old grease causing a weight difference on the u joint... good now :D
