Vibration
After seaching I cannot find a solution to my vibration problem. Before the cruiser was lifted it had a vibration at around 65-70mph. Now after a 4" Alcan lift with Daystar super shackles I have a vibration that starts at around 30mph and gets a little better at 55mph.
The things checked are new u-joints,driveshaft in-phase and pinion angle checked with t-case angle. It has a Aussie locker in the rear and I had a little slop in the pinion rotation wise so I install a new pinion seal and nut (stacked)
Could the vibration be coming from a bad pinion bearing and if so what is the best way to chack it ? (I have no side to side slop)
Thanks
Burl
Does the vibration correspond to when the rear Aussie Locker was installed ?
I've got a bit of new vibration in my truck and it corresponds to the rear locker install.
Cahil
Yes it did seem to start shortly after the locker install cahilc
Burl
No David I have not checked that what is the best way to check it ?
Thanks
Burl
Sorry forgot to mention new TR ends all around !!
The problem seems to be in the rear can someone tell me the best way to check the output shaft bearing do I just need to pull the cover off or is it more inside than that ?
Thanks
Burl
here is a funny FJ40/60 fix for driveshaft vibration.............. .everytime you go to a oil change joint they just pump away........
Simply remove your Slip yolk zerk and let the excess grease/pressure out.......
Razor did that to get the driveshaft back in but will recheck to make sure !!
P.S nice avatar(sp)
Burl
Since you're working on a couple of theories - what about driveshaft balance? I had my u-joints replaced, and got a vibration afterwords at around 2500rpm. It was the driveshaft. Got it balenced, and it's now real smooth.
Wierd about it happening after the locker install though...makes me think it's "downstream" of the locker - as in wheel balance?
By the way, I learned (on this board) that vibration through the steering wheel is in the front, and if felt in your butt is in the rear. Easy to remember!
lovetoski I think my next plan of attack is to have the driveshaft balanced. Since one more thing I forgot new tires with very few weights tire guy said they were best he has seen for awhile in a 33" tire and I trust him since I was watching !!
Thanks
Burl
Thanks
Burl
I agree with the post about cleaning out your slip joint on the rear shaft and balencing it. To check the output drop the shaft and grab the output flange. You will get a bit of slop in it from the gear lash you should not get any wobble in/out or side to side.
Good plan and great advise.
My bet is on the locker install. I've picked up a bunch of random vibration after my rear locker install. I'm a fanatic about vibration, or better put a lack of it. Still unresolved for me. Might now be a feature.
Cheers,
Cahil
If you can find an experienced tire balance mechanic they can take a test drive and not only tell front/back but left/right too.
Cahil
One thing to watch is the location of the driveshaft to the diff.
When I put my lockright in the back I marked the shaft and the pinion with a punch. The Workshop manual made a point of recommending this in LARGE BOLD PRINT.
You could try turning the shaft 90-180-270 degrees (I know its a pain but at least its free)
Should be fine as long as it's not 'phasing'.
Basic/simple translation you want the U joints lined up with the same angle to each other. If they are 90 degrees offset then they will help each other vibrate more ... read up more on this as I have a very basic understanding of the concept.
HTH,
Cahil
Thanks David and to everyone for the help. I called today about getting the driveshaft balanced and rebuilt if needed. I need to pull it off this weeekend and see, while checking that output shaft bearing.
A little more about the problem is that it seems to vibrate underload (on the gas) and less to none at no load (off the gas). The other thing is when shifting from fwd to reverse there seems to be slop in the pinion not in and out or up and down but just in rotation.
Thanks
Burl
R+P backlash or the front pinion bearing or a combo. usually the case espcially if the locker was installed w/o putting new OEM/Koyo pinion bearings under the correct preload.
Keep us posted!
UPDATE: I have tried rotating the driveshaft 180* on the pinion ,pulled grease zirk out bottomed shaft by hand and checked output bearing ALL with NO LUCK !!
Next step: I have a friend from work making me 4* castor shims will try those.
I plan to pull the driveshaft and have it checked ASAP
After that I plan to put new bearings in the diff.
Thanks for ALL the help I have been getting hope to soon solve this problem!!!!
Any other suggestions I'm always open to suggestions?
Burl
Usually vibration under load is not driveshaft. The drivetrain get under tension and prevents the wobble, let off the gas and it wobbles and vibrates. The slop is sorta normal for any lunchbox locker.
