A few days ago, my 62 suddenly developed a vibration/rumble strip noise at speeds above 50 mph.
The whole car does NOT shake, its just a deep vibration that is very loud- sounds like you are driving over a rumble strip constantly. Most of the noise goes away if I take my foot off the gas driving at freeway speeds, but comes back instantly if I start to accelerate again.
Today I changed the transfer case oil- was pretty low and filled mostly with ATF which I guess had seeped in from the tranny. Drained this out and put gear oil back in. Cleaned drain plug magnet which was coated with a layer of very fine material (dust like) then underneath that a thin layer of small metal shavings.
Got back on the interstate and vibration did not change.
Took the rear driveshaft off, and running it front wheel drive, the vibration disappeared.
The u-joints on the rear shaft seem very solid with no movement that I could tell. The transfer case rear output bearing has very small amount of play in all directions. The x-fer case front output bearing has some play in all directions, noticeably more than the rear.
Does taking the rear shaft off isolate the problem to one of the u joints on the rear shaft / the shaft itself OR could the transfer case still be the cause of the vibration?
Also, do I need to cover the wholes left where the read DS connected to the differential or t-case? Can water get in there? I am going to be backing a boat down a ramp tomorrow, and the rear differential will be likely submerged. With the DS off, will this be an issue??
