I’ve done a search and can’t find anything that actually matches this issue exactly as the issue is happening only at specific times (though I’m sure there is).
Whats happening is I’m getting a pretty solid feeling vibration/shudder generally only at higher rpm’s and only in a high torque situation. The best example I could give is if I am driving up a steep grade and I step on the gas to keep the speed, the vehicle may or may not down shift (meaning doesn’t matter what gear it’s in) and it will vibrate or shudder until I am off the gas or really when there is less torque on the engine/trans. Another example is if I am getting on the freeway “stomping” on the gas ( doesn’t do itt if I’m gently on the gas) it will do the same thing until I get to speed and let off the gas.…. To be more clear it’s basically only when there is a high load put on the vehicle as I could be at the same speed at same rpm without a high load on the engine/trans and it is smooth as silk without a load.
Thanks for any input.
2003 LX470
2003 LX470
