Variable Twin Scroll Turbo on a diesel, opinions please from turbo guru's
If you are interested in understanding how the twin-scroll system works have a look at this link: https://www.mhi.co.jp/technology/review/pdf/e501/e501023.pdf , it is very important the firing order of 1,3,5 and 2,4,6 are grouped, and the firing order of a 12-ht is 1-4-2-6-3-5, which is different from most inline 6 engines with 1-5, 3-4, 2-6, just check the corresponding ports are going to the correct place. For a 12-HT, cylinders 1,5,6 need to be matched and 2,3,4 also, unlike most with 1,2,3 and 4,5,6. I am currently producing a stainless equal length twin-scroll manifold for my 12-HT 60 series and if all goes well I could look at making a few if others were interested.
If it isn't quick enough spooling you should look into using a quick spool valve, which diverts the gasses on one scroll to go thru the other, which means for the gas to pass thru the smaller volume it has to increase in speed which in turn spools the turbine faster, then at higher boost levels the valve opens allowing for the full flow of both scrolls, kinda like a variable geometry turbo but much cheaper and less moving parts.
