vapor lock???
Discussion in '60-Series Wagons' started by hullendersauce, Aug 8, 2005.
  1. hullendersauce
    hullendersauce
    414
    2
    Jun 4, 2003
    Westminster, CO
    '87 fj60, runs great allllll day. if i turn it off for 20-30 minutes and get back in...its hard to start. also, i notice when i loosen the gas cap, gas & fumes come sprayin out at me. i popped the passenger/inside 1/4 panel off, and checked all the hoses, and that "lil black thingy" (where all the hoses connect to), but all looked fine.
    buddy told me it could be up by the charcoal canister, up by fuel pump. i checked the (3) hoses that were connected to the top. both smaller hoses were fine, but the thicker hose (approx 2" long) had a small weep hole in it. does any of this sound familiar? sorry for the long example...-other sean
  2. Fearnofish!
    Fearnofish!
    260
    Jun 7, 2005
    Hamilton, MT
    Does sound like vapor lock, but those hoses do not sound familiar. I'd go shotgun and start cleaning the simplest things first. Hoses and filters. Then address the money items like vapor recirulation components.
  3. Doc
    Doc
    5,925
    Media:
    33
    Albums:
    1
    430
    Apr 26, 2004
    Utah
    Is your carb cooling fan working?
    Your syptoms sound like mine did- my problem was a fuel pump on the way out.
  4. hullendersauce
    hullendersauce
    414
    2
    Jun 4, 2003
    Westminster, CO
    well, my carb fan WAS working. that was the 1st thing i checked. when i wiggled the wires, it would cut off and on. i took the wire comming from the block to the carb fan off, and will have it replaced later today. i hope its just my carb fan shorting in/out, causing my carb to overheat...ie: vapor lock.
    as far as the fuel pump...i had just replaced it last year.
  5. PabloCruise
    PabloCruise SILVER Star
    17,419
    2,118
    Jun 3, 2004
    Northern Colorado
    Get that carb fan running well.
    Make sure your charcoal can is not plugged - can you blow into it via the intlet hose? There should be a a vent at atmospheric on the bottom.
  6. hullendersauce
    hullendersauce
    414
    2
    Jun 4, 2003
    Westminster, CO
    follow up
    so...end result (i hope). i changed out the ground wire from the block to the carb fan. now i have fan!!! i also changed out my fuel cap, and WALLA...no more hesitation/fuel-splash-back. i havent driven it much to really find out if these were the problems, but as of right now, its seems to run fine. i mustve damaged the fuel cap when i ran Spring Creek, CO trail, and it wasnt venting correctly. we have a cool front commin to CO, so once it gets warmer outside, ill check my symptoms again. thanks for all the help!!! -other sean
  7. PabloCruise
    17,419
    2,118
    Jun 3, 2004
    Northern Colorado
  8. nuclearlemon
    nuclearlemon not an addict Moderator
    16,254
    Media:
    87
    Albums:
    4
    1,108
    Jan 30, 2003
    meh-ico, colorado
    sweet...glad it's better.
  9. hullendersauce
    hullendersauce
    414
    2
    Jun 4, 2003
    Westminster, CO
    thanks Iggy. w/out talking to you, i wouldnt have even thought about my gas cap. any fix for $5, is kik ass to me!!! -other sean
