Been reading through some of the old threads but haven't found my answer yet. I've adjusted the valves a couple of times and everything is in spec... but when engine is hot and under load, I get some crazy valve clatter. Especially bad in long gears uphill or starting from a dead stop if you let it bog down a tiny bit. None of this happens in neutral or if I'm on flat road or going downhill. It does it a little bit when cold but not bad.
