Last week I drove my 76 Fj40 to breakfast (DD) and it ran perfect. Came home for a few hours and went out to start it. Sounded like someone drop marbles in the motor. Pulled the plugs and the insulator in #5 was gone. Installed new plugs and still sounded bad. Pulled plug #5 and tip was crushed.
I used a scope and ended up fishing a few pieces of metal out of the cylinder. I ultimately pulled the head and later, all of the pistons. Pictures show all 6 pistons, left to right. As you can see in pic of the bottom of the head, the valve seat is no longer visible and I ultimately removed the remnants from 2 other cylinders (pic#3).
The head is toast but a buddy has a rebuildable one for me. I plan on ordering new pistons, rings and rod bearings. I’m praying that I only have to hone the cylinders as I’d refer not to actually pull the motor. Any thoughts? I do believe the engine has ever been rebuilt so hopefully standard sized pistons with new rings will suffice.
