Valve clearance for Man a Fre Rv cam
Boulder County Colorado
Anyone know the correct initial valve clearance for the Man A Fre RV Cam?
Their website says intake .012 Exhaust .014
It makes sense to me to use the standard Toyota recommended
.008 intake and .0012 exhaust.
they sell a new valve spring set with their cam kit and recommend the new settings for the kit.
I purchased the cam alone (no kit) as I had already done the head job including new springs...
This is a rebuild and I want to adjust the valves for initial startup, then readjust after a couple hot'/cold cycles and after headbolt retorque
Just double checking with the MUD guys first.
Those look good to me and are what I recommend with the regrinds I use/sell.
Mark...
Not to hijack,
Mark, do you different springs with the regrinds from Delta cams. I am using new stock springs with one of there re-grinds.
thanks
Ryan
I have never needed to run anything but stock springs... it is close but they work without bind and hold the valves in excess of 5 grand
all i need :)
Mark...
