Valve chatter at high rpm’s
Mill Valley, CA
So on the way back from surf n turf I was experiencing valve chatter when on the freeway in 4th gear. It would only happen when I would load up the truck i.e. going 55mph and give it more gas. It only seams to happen under load. What could be causing this? I ran a quick go-no go valve clearance check and they were all right on. Intake .010” and Ext .014”. I am running a E-67 135 F motor with the timing bumped to about 10* with a NON-USA distributor
Thanks for the help
Ian
Just last night I noticed a chatter and thought it was valves at high rpm but discovered that my clutch slave needed a little adjusting. Sound went away with a little pressure.
Just trying to eliminate the obvious (or stupid stuff) first. :)
Thanks for the help
Ian
Sounds like spark knock, preignition, whatever. Low octane gas and/or too much advance under load is the usual culprit.
If you were to keep your foot in it while it's doing that you could find yourself with a hole in a piston, but most of the time if you just back off when you hear it you'll be OK. I wouldn't use the sound as a tachometer - waiting for it before downshifting or letting of the gas. That's a dangerous practice.
Yep. Ping.
