Vacuum T-Case to Manual Shift - Interested in a kit?
Discussion in '60-Series Wagons' started by cruiseroutfit, Jun 12, 2018.
  1. NCFJ
    NCFJ Supporting Vendor
    7,708
    7,779
    Jan 22, 2007
    Chesnee, SC
    If a person is switching to manual with this kit I would suggest going with a set of twin sticks (they come with linkage). Much easier to come by than sourcing an original 60 series single stick and linkage. PLUS you get 2WD Low.
  2. ceylonfj40nut
    ceylonfj40nut Hate Design Obsolescence SILVER Star
    1,108
    1,467
    Jan 11, 2015
    TX
    Kurt, so I would need an outside linkage also? Any pics to show what your Parts connect to and what other parts are needed? That will be helpful to many
    cruiseroutfit likes this.
  3. beno
    beno Gihee Arakawa Moderator Supporting Vendor GOLD Star
    24,771
    Media:
    382
    Albums:
    29
    21,769
    Aug 28, 2004
    Woodstock, NY, USA
    Pretty much most of these pieces.
    Plenty available in the used market.
    ceylonfj40nut and cruiseroutfit like this.
  4. cruiseroutfit
    cruiseroutfit Supporting Vendor Moderator
    8,543
    6,110
    Jan 9, 2003
    Utah
    Good, we sell full t-cases too :D
  5. cruiseroutfit
    8,543
    6,110
    Jan 9, 2003
    Utah
    Beno nailed it. I'll look into the linkage at some point but the goal of this currently a kit to use an FJ62 case in a manual setup truck.
    Spike Strip likes this.
  6. cruiseroutfit
    8,543
    6,110
    Jan 9, 2003
    Utah
    Is someone offering a (edit: different) Split-case twin stick kit as of late? Or still modifying the 1-pc setup/AA style? That is a great linkage solution though the AA Option does use a modified shift shaft, we could absolutely accommodate that too but then it's a second kit :D
  7. beno
    24,771
    Media:
    382
    Albums:
    29
    21,769
    Aug 28, 2004
    Woodstock, NY, USA
    The good thing is that the later HZ7x mechanical transfer cases pretty much used almost all of the same 60 series components with some slight differences and part numbers.
    All of these parts are still available and thus one could ostensibly just use 7x series linkages in place of the 60 linkages for the conversion if folks wanted to use new OEM parts.
    Here is an HZJ78 linkage system. Almost identical.
    bwesty, Jaric00n, red66toy and 4 others like this.
  8. Dynosoar
    Dynosoar Slightly Disturbed SILVER Star
    3,770
    473
    Feb 4, 2006
    SoCal
    MANUCHAO, Spike Strip and NookShneer like this.
  9. ceylonfj40nut
    1,108
    1,467
    Jan 11, 2015
    TX
    Beno
    Thanks for sharing! Awesome.
  10. 4Cruisers
    4Cruisers SILVER Star
    3,389
    3,298
    Apr 2, 2015
    I converted my '89 FJ62 transfer case to manual by buying the needed OEM parts from American Toyota in Albuquerque with a MUD discount. It's mated to a new H55f I bought from Cdan well before he retired. The combination is in my '86 FJ60, which (I hope) is only days away from being completed. I was able to use the linkage components from the '86, but have bought several sets of used linkages for other transfer cases from @cruiserjunktion.
  11. cruiseroutfit
    8,543
    6,110
    Jan 9, 2003
    Utah
    Ah yes but AA's uses the split shift shaft so that would make this one a moot point. @orangefj45's would certainly do the trick. There is an easy answer.
    The used linkage shouldn't be difficult to track down. Later model stuff is available as Beno pointed out and SOR is reproducing several of the parts as well. I think our kit is just going to focus on the t-case portion itself, thus making a better market for some of the new parts we are taking out of t-cases and/or for folks with a used 62 case and want to put that in an older 40/60.
    Thanks for all the input guys, keep them coming!
  12. Spike Strip
    Spike Strip Torque Ain't Cheap SILVER Star
    12,829
    3,081
    Nov 22, 2005
    A Sh!thole
  13. cruiseroutfit
    8,543
    6,110
    Jan 9, 2003
    Utah
    No, but I can have a part number tomorrow :D
    Give me a shout and I'll assemble some kits :D
  14. Spike Strip
    12,829
    3,081
    Nov 22, 2005
    A Sh!thole
    Will do. Cheers.
  15. NookShneer
    NookShneer GOLD Star
    1,255
    Media:
    9
    Albums:
    2
    1,322
    Aug 4, 2010
    North of Seattle, WA
    @cruiseroutfit
    I just ordered a tap to do this on my transfer case. Can I donate it when I’m done to the traveling tap install program?
  16. cruiseroutfit
    8,543
    6,110
    Jan 9, 2003
    Utah
    It's in the computer :cool:
    Part# TCMANCONV - $145.00
    @Spike Strip, yours is packed and headed
    davegonz, g-man, abtx4x4 and 6 others like this.
  17. cruiseroutfit
    8,543
    6,110
    Jan 9, 2003
    Utah
    I'm sure someone will take you up on that! :cool:
    Spike Strip, 89BIGBLUE and NookShneer like this.
  18. Spike Strip
    12,829
    3,081
    Nov 22, 2005
    A Sh!thole
    cruiseroutfit, 89BIGBLUE and MANUCHAO like this.
  19. cruiseroutfit
    8,543
    6,110
    Jan 9, 2003
    Utah
  20. davegonz
    davegonz Keeping it Weird SILVER Star
    8,106
    Media:
    17
    Albums:
    3
    2,281
    Sep 15, 2004
    Austin, TX
    I want a shirt!
