From the 3FE files section:
Subject: Re: [3FE] 4x4 selnoids
Date: Thu, September 23, 2004 10:00 am
To:
3FE@yahoogroups.com
Priority: Normal
from a 90-1 Celica for the AC idle up, list price is $17.60 part # is 88690
2B340
so if it works(and it should) it can save folks for having to hit the
wreching yard, can get a new pair for $30
I will snap a better pic.
John
>That Celica solenoid looks exactly like the one I pulled from an '86
>Corolla to fix my 62. And yes, it fits the bracket. Please do get the
>P/N.
>Wayne
> > I mentioned a week ago I used a celica vacumme switch on my 82 fj40 for
> > my AC idle up. cost $17 new at the dealer vrs close to $100 for the
> > correct one(actaully for a fj60)
> > I am SURE it will work to replace the 62 vac swtich, only difference is
> > the pins for the wire harness, the celica switch uses normal female
> > spades, the 62 uses small pins, so just need to change the ends or make
> > a jumper for the OEM harness to the celica switch. I bet they will even
> > fit the 62 mounting bracket.
> > here are some pics.
> > fj62
> > celica
> > sorry the celica pic came out crappy, I'll snap another one.
> > I can call and get the part # if wanted.
> > John H
And if you are too cheap to buy it new:
Well I went to the salvage yard today. I looked at all
the Toyota's I could find in the mid to late 80's. I
found an 1987 Toyota Van. On the side of the motor
towards the rear passengers side you will find the
three port 12VDC vacuum switch needed for the 2WD
replacement. Guess what... it uses the same plug that
the Cruiser does... just shave off the tit and remove
the switch from the bracket and swap it with the one
from the cruiser.... bolt everything back on and
walla... it works... YES! No wire cutting and
splicing... I am sure an 1988 or even an 1989 Toyota
Van would work just as well.... I am very happy.
I'll look for past posts on replacement switch numbers.
Here is another alternative solution:
Subject: [3FE] 4x4 vacuum solenoids
I have been looking and can't find the post for the MAC valves part
numbers(or any other fixs) to replace the vacuum solenoids in the 62.
I copied this from a former post:
ok this is the solution
parts:
mac 35a-aaa-ddba-1ba valve 12v-qty2 total 34.00
arrow asp-1 exh muffler-qty 2 total 3.20
28-4-2 parker fitting-qty 4 total 2.44
total for two complete valve assembilies 39.64
extra standard rubber vaccum line like is already on the truck.
the mac valves have three slots for the fittings
i used teflon tape to get a good seal
the exhaust fitting goes in the top numbered 3
install the parker fittings in the other two screw intakes
the line from the manifold goes into the fitting that is marked 1
on the mac valve
the line from the transfer goes into fitting marked 2
cut the old wire leads off and connect the mac valve leads
connect the vaccum lines
for the mounting bracket i used a piece of alum. and formed
a bracket.
Dennis McCarthy-
And another:
Fix for Vaccum Selonoid Transfer Switch
By Keil Thompson
Here is the solution if your vaccum selonoid fails:
Parts:
mac 35a-aaa-ddba-1ba valve 12v 2 each total $ 34.00
arrow asp-1 exh muffler 2 each total 3.20
28-4-2 parker fitting-qty 4 each total 0.44
Grand Total for two complete valve assemblies $39.64
Installation:
The mac valves have three slots for the fittings.
I used teflon tape to get a good seal.
The exhaust fitting goes in the top numbered 3.
Install the parker fittings in the other two screw intakes>
The line from the manifold goes into the fitting that is marked 1
on the mac valve.
The line from the transfer goes into fitting marked 2.
Cut the old wire leads off and connect the mac valve leads
connect the vaccum lines.
I formed a mounting bracket out of aluminum.
To find mac valve dealer go to
www.macvalves.com
I got mine here in ga. from tsi solutions 770-879-3500 but i think
that they only sell in georgia
Good Luck,
Dunbar
