Vacuum Shift/Floor Shift Kits
Gig Harbor WA
I think all you need is the lever and the bits on the t-case, it all should bolt right up, give James at Cruiserparts a ring, I bet he has the stuff you need.
John
Kansastitty
You might also try Landcruiserparts, email: Viccin@centurytel.net
They're good folks to deal with, and they don't ream you on shipping.
HTH
Ed Long
Georgia Tech
All you need is the top plate with the manual shift linkage. I would search around for a parts truck or someone's old t-case. pretty sure 3 spd and 4 spd top plates and linkage will work.
Scott68FJ40
Olympia, WA
Website
www.myblueheaven.com
I did mine not that long ago. There are a number of linkage parts but if you look at it long enough you will see how they all fit together.
The parts to convert the TC shifter can be a little expensive but if you look around you will find a deal.
Website
www.urbanlandcruisers.com
Best way to get floor shift is to buy a used 3 spd and have the seller remove the top plate and shifter and send them. Them throw the rest away! WHy convert from vac shift on the case? It works great and almost never breaks down. Less to go wrong than direct shift. Just replace the hoses and go. I would go with Land Cruiser Parts if you want to get rid of it. Vic is a good guy
Cherry Valley, NY
My '70 had the vacuum shift and I used 2Lo a bunch of times. Bear in mind you cannot disengage the front end without the engine running--need vacuum in both directions.
Website
www.autohomeus.com
I put 150,000 miles on my '71 FJ40 and never had any problems with the vac shift - and they DON"T RATTLE.
The cool factor may be the real issue, eh?
Mike S
Georgia Tech
[quote author=Mike S link=board=1;threadid=6575;start=msg53968#msg53968 date=1066866363]
Mike S
[/quote]
I don't know man, vac shift is pretty cool in the sense that not many trucks have it anymore. Other than 62's.
Website
Forgot about the 2 low! even more reason to keep it.
Website
www.autohomeus.com
CruisinGA:
Yup. Cool is old original s**t that works. Some of the new stuff ain't better, just different.
MS
Scott68FJ40
Olympia, WA
Website
I have a complete vac setup that I took off of my '68 FJ-40 if anyone wants to make me an offer.
Wherever the truck stops!!
Website
wirrell.com
[quote author=CruisinGA link=board=1;threadid=6575;start=msg53485#msg53485 date=1066782653]
[/quote]
I don't like to rain on anyone's parade but the top plate of the transfer cases are different for 3 speed and 4 speed (shift dog is 90 deg. different between 3 speed and 4 speed), and the top plate does NOT enter the equation on vacuum shift. The vacuum part is on the transfer front extension housing. Top plate shifts between hi/lo and the front extension housing shifts between 2wd and 4wd. The front extension housing shifters are also different. The three speed one is shorter than the 4 speed one.
I have all the parts (except shift knob) for the 3 speed transfer floor shift if someone needs it.
Georgia Tech
No feelings hurt, my bad. I had my facts wrong. Guess I was mixed up between 3 spd tranny column to floor shift and 3 spd t-case vacuum to manual linkage. :doh: :slap: I'm kinda suprised David didn't catch my mistake, he tends to be apt to correct my unfortunatly somewhat numerous mistakes. :flipoff2: :D
