Hello All,
I recently purchased an ‘81 BJ40 w/ a 3b swap (RHD, 12v). I’ve been reading through these forums for the past several months, and you all have been crucial in helping me work on this truck, and I thank you for that. This is my first post, and I’d really appreciate any help you could provide regarding the 3b alternator, specifically the vacuum pump hoses. The PO swapped out the stock alternator for a single wire NAPA replacement, and piggy-backed two Dorman vacuum pumps to run off the ignition wiring. Since these pumps aren’t intended to run around the clock, naturally they are burning up. I’ve installed four wheel disc brakes, but the brake pedal is hard as a rock, and will only move about an inch. I suspect the vacuum pumps are the culprit, and have ordered a stock alternator from Cruiserparts. Problem is, no one stocks the vacuum inlet/outlet hoses. I ordered through amayama, but they are discontinued. To those who’ve had custom braided hoses made, what specs did you give to ensure banjo fittings and hose diameters were correct? Without the stock setup or FSM, I’m shooting in the dark here. Any help from fellow Cruiser owners would be greatly appreciated.
