Vacuum hose? Hook up with 4runner booster?
phishtaco
Cincinnati
Cincinnati
Does this vacuum hose get hooked back up with 4runner booster set up? Installing new MC and t4r booster right now.
On the end is a one way valve, some boosters use that type, that goes into a grommet in the booster. Most 4Runner boosters take a one way valve that goes inline, we usually take the line with valve from the donor rig.
I had the same issue when I swapped in an 80 booster. Toyota couldn't find me the part without a serial number... The diesel JDM 80 had a vacuum pump so it's serial number didn't help. The VW parts supplier had no problem supplying the needed check valve. Volvo and many others also use them. eBay has a slue of them... Doesn't help when you're driving around without one.
