Vacuum diagram, where to find
Minneapolis, MN
I just bought an 73 fj but the vacuum system is jacked! All of the hoses are disconnected so I don't know what goes where. The Max Ellery manual has no vacuum diagram to work off of, so do you guys know where I can find a vacuum diagram (Haynes maybe)?
:cheers:
PabloCruise
Northern Colorado
Tatunka,
Welcome to MUD!
Your best bet is the Emissions Manual from Toyota. You can get it from a dealer, SOR, or Cruiser Dan.
It will line everything out, and is broken into a systems view...
Good luck.
Also, search for a post by LandPimp about factory vacuum tubing part numbers. It will fit better than tubing from a parts store!
Pin_Head
OC, CA
Here is the factory diagram for a '76. Unfortunately, the '73 is very different. Try SOR.com. they have some vacuum diagrams, but they are pretty small.
mwalls54
Cruiser Nutjob
Roanoke, VA
haynes manual has a good diagram of the f engine vaccum lines, I only run about 3 lines if that,
